Power window and door lock control not working.. please help
i noticed today that my power window and door locks are not working from the drivers side control panel and other doors expect the drivers windows. it does not respond to the other windows and door lock and unlock. i tried the switch on all the doors and window lock and they are not responding. if i hit the key to unlock and lock the doors they work but not from the switches on the the door control. what can the problem be? i looked at the fuse by the battery for the power windows but its a fuse that is connected to 2 other things. i really need some help guys. its a 2007 g35x.
Start with the simplest explanations first. Check the window lock switch first by switching on and off a few times. If not, your DS master switch may be defective and you'll need to disassemble the door panel to remove it. Not sure how you're going to test it, but you should check the FSM for specifics.
cconklin2
01-09-2016 07:21 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
