HELP: Osram Xenarc 66240 CBI Upgrade...Something isn't right!
#32
I just don't want to go over there and "accuse" them of the damage, wouldn't want to cause a scene. I rather explain to them how the damaged might have occurred and hopefully work it out from there.
It is hard to be civilized with them.
So far, I have not had any oncoming traffic high-beam me or other issues from any driver on the road regarding the lights.
I'm concerned that if I raise the driver's side higher it might be too high...since JT raised the passenger's side.
The cut off of the passenger's side right now falls right under the license plate of the car in front...such as Honda Accords, Toyota Camry...etc.
Is this level seem correct?
If it is, then maybe I should adjust the driver's side a bit higher so the top of the cut off will be level with the bottom cut off on the passenger's side.
Please let me know.
Thanks!
#33
I tried to contact them today, but no answer...maybe they were closed due to MLK day?
Please let me know.
Thanks!
Please let me know.
Thanks!
#34
Thanks! ![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
Just spoke to Brian over @ JT regarding the issue and we are working out the situation in order to correct the broken clip.
Thanks Brian for your understanding/professionalism regarding this situation and coming up with an agreeable solution.
I will post an update as soon as this issue is resolved.
#35
#36
You guys are nuts! Its so funny to see what people put them selfs through to save a few bills.
To the OP why on earth would you pay $40k plus for a new car then buy new head limp lights then go cheap on the install by going to a half *** hole in the wall place. Why not just go to the dealer and have them install your new lights in the first place. This is why I don't by used cars. You never know what some egg head was doing to it.
Just FYI the PIAA HID lights run at 6600K and have the best light output!
Ballers only!
http://www.piaa.com/store/p/471-D4R-...Hid-Bulbs.aspx
Ballers only!
#37
![Wink](https://www.myg37.com/forums/images/smilies/wink.gif)
Ballers only!
PIAA | D4R Super Cobalt Hid Bulbs #19996
Ballers only!
As far as D2S HID bulbs go, either the Osram CBI or SVS are the best out in the market.
Saving a few bucks isn't the question here, but actually non Infiniti OEM parts such as these Osram bulbs is something my Infiniti service would not do.
My situation is not typical, so don't let my experience base your opinion on all speed shops.
Accidents do happen.
There are some really good ones that can be even more knowledgable than the dealer.
I'm just glad that my issues will be addressed and resolved soon.
#38
6600k is too blue .. Not the color I want on my 40k car. The whiter the better IMO.
D4S bulbs can work in a D2S system, you have to cut a notch in the base of the bulb to match the D2S. But really the only difference is the D4S is mercury free, not worth the money or trouble.
OP if JT screwed with the passenger side, then lower it to match the drivers side.
Then you should be all set.
#40
#42
I would think at 6600k, there's got to be a lot of blue hue to them...not as much as 8000k though.
I thought $185.00 for a couple of bulbs were expensive, but $350.00...way out of my reach!
So far, with only about 15+ hours on the Osram's, they are looking brighter & whiter.
Can't wait until they are fully burned in and correctly adjusted
#43
The headlights cut offs were hitting the lower part of the bumper of the vehicles in front of me.
Now the passenger's side is right under the license plate and the top of the bumper.
I will have to see next week when I have JT "repair" the issue with the headlight and have them adjust them to the correct levels.
#44
If they did, consider yourself lucky!
My dealership frowns on any non Nissan/Infiniti parts...
![Mad](https://www.myg37.com/forums/images/smilies/mad.gif)
