Xirallic in Smoky Quartz paint?
Xirallic is a pigment which gives paint a vivid, lustrous look that was never before possible. It is made in Japan by Merck. As of now, the Japan operation is the only plant in the world that makes this product. That is why after the tsunami there, every major auto manufacturer stopped painting colors with this pigment. The plant had been shut down. There is no substitute for Xirallic. The plant is operating at full capacity again. Supposedly another plant will be built in Germany so that supply will not be interrupted again.
Here is Merck's Xirallic web-site: Merck Performance Materials - Xirallic
Ridiculous. Just did some research on the Spies Hecker paints I use everyday and some of the higher end pearls we are are in fact xirallics, but are not labeled xirallics in any way!
They are definately more brilliant than your standard pearls.
What is the paint code? I will look it up
Todays Paints
Honestly gentlemen, some of the paints and so called metallic like finishes don't do that much for me. The technique of using a color coat and then covering it with clear just doesn't bring out the depth that you used to get with the older types of paints that were used before the EPA forced these new paint types on us. Yes the cars look shiny, but they rarely have soul when you look into them. They also don't have much real depth which made you feel you could dive into the paint, that's how deep it looked. I've seen very few high end cars whose paint jobs really wowed me. Surprisingly some of GM's more recent paint colors have shown real potential, especially in the metallic reds. They had great color and decent depth and a fantastic shine. This before being professionally detailed. JMO-ICBW
Al
Al
Sory i have to disagree with you track bandit, todays colors completely destroy anything from the past.
You will rarely get your "soulful" colors from the factory.
Check this site out. Alsa Corp | The World's Most Exotic Paints and Finishes
Check out their candy concentrates, and some of their pearls, alsa is definately one of, if not the leader in custom automotive finishes.
OP, checked the color code you gave me, reads as Desert Shadow, and there are no xirallic pigments in the color. I can upload a picture later of everything that is in that color if you would like
Al
Al
You are dead-on about modern paints destroying the old ones. The 1967 Corvette had a color called Marlboro Maroon. It is similar to the Monterey Red color on my 2006 Corvette, but does not have the brightness or depth of Monterey Red.
Picture upload not necessary. Thanks again.
Phil
ck1109
10-15-2015 11:06 PM
automobile, automotive, car, colors, custom, forum, future, g37, infiniti, paint, quartz, smokey, smoky, xirallic, xirallicdupont
