Auto windows not working properly?
I have an 09 g37 coupe 6mt. I recently installed the stillen gen 3 intake. That is the first and only mod i have put on my car. It sounded good and everything was working fine except when i rolled down my windows, they went down automatic like always but once i pulled up on the switch, they would only come up if i held the button down. I was wondering if anyone would know what could be wrong with it. I was wondering if unplugging the battery could have caused this or anything. Please post any helpful suggestions or knowledge on the subject. Thanks
There is a Recall on the window switches...I had mine changed out a few months ago, but the ones they replaced were bad too...same stock #. Going back next week...its free of charge just call your dealership.
Mine is a 2012 G37S but go to Infiniti.com put in recall and will show the recent ones which are the window switches...mine did the same as yours yet my car is new sometimes it would roll up and stop and roll back down....Our G's are possessed!
This is a window timing problem, it can also be because of a low battery. The Dealer fixed mine for free and replaced my battery (I am still under warranty). This URL details how to fix the timing issue yourself:
How to retime an Infiniti G35 and G37 window and moonroof
I also have this problem... I press the auto up button, the window goes up and when its about to reach the rubbero stop to close the window it stops then goes back down automatically and stops at about half way! then I have to press and hold the window switch to completely close the window. Is this the same problem you have that there is a replacement switch for to correct?
Ok let me know the new part number when you install it...
Any time you disconnect the battery, you will need to reset the windows. This may take several attempts so repeat the process a few times. Roll down the windows while keeping the buttons pressed down the whole time. Keep the buttons pressed until you hear a click from the window switch solenoid. Now roll up the window to the top while keeping the buttons pulled up the whole time. Keep the buttons pulled up until you hear the same click from the window solenoid. Try the auto window up and down to see if they are reset. If not, repeat the procedure.
I've had to do this in the past after installing mods and it should work as long as your battery is not faulty.
Yes try that but it sounds like something different from the window reset. My Z has just started doing this same thing. somethimes while rolling up the window it will get about half way and just reverse. I have never had this happen in the G but we don't drive the G much, even less with the windows down.
Ill do that...it was a national Recall on the switches...look it up online...just make sure they got the new switches in...ones they had in stock were faulty ones like the ones installed from factory...once I get it in this friday ill pm you on the stock #
stealth210
General Tech Questions
27
07-26-2017 06:48 PM
