Notices
Clear lens.. Worth it?
Old 11-14-2012, 12:04 PM
Abramite
Abramite's Avatar
UPDATED 11-25-17
I have a set of tsx clear lenses. Any one have these installed in their projectors? Is it worth the hassle of installing? Do you have pics of output?
Got around to finally doing it.
I added a genuine tsx clear lens and removed the secondary shield inside the projector. I’m sure you can tweak it more, but I’m happy with the results - stock on top, modded on the bottom.
Old 11-14-2012, 01:05 PM
TruLux
TruLux's Avatar
Are our stock lenses the same size?
What's the diameter?
Old 11-14-2012, 01:09 PM
Kidcane
Florida G Club
Kidcane's Avatar
They are a pita to instal but I had them put in when I had the rest of my headlight work done. IMO one of the best headlight mods. Makes the light output so much cleaner.
Old 11-14-2012, 01:19 PM
chilibowl
chilibowl's Avatar
1000% worth it. Output is enhanced drastically and the cutoff is so sharp and beautiful. You gain a nice blue band at your cutoff line.
5000K bulbs with TSX clear lens = ****
Old 11-14-2012, 01:23 PM
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
Yeah, the light is much clearer and the cutoff is sharp and nice
Old 11-14-2012, 01:28 PM
CRV_33
CRV_33's Avatar
I agree. Someone local had them done and it makes a huge difference!
Can'tGme
Can'tGme's Avatar
like kidcane said, pita to install but worth it
Old 11-14-2012, 03:24 PM
Abramite
Abramite's Avatar
Did you guys do it yourself? Or have someone else do it like 180. If so what was the price?
Old 11-14-2012, 03:30 PM
Weiboy718
Weiboy718's Avatar
It's one of the easiest mod to do once you open up the headlight housing. Unless guys are not removing the whole projector out of the slot and try to pry open the lens cover.
Op, where are you located?
Old 11-14-2012, 03:41 PM
Abramite
Abramite's Avatar
Wisconsin.. Why? You nearby?
Old 11-14-2012, 03:52 PM
BeefMaster
BeefMaster's Avatar
The lens only makes the cutoff more sharp. It does not affect the output from my experience.
Old 11-14-2012, 04:07 PM
Abramite
Abramite's Avatar
I agree, the output is based on the projector design. You wouldn't get more output, but with a clear lense you would get maybe more intense light toward the middle of the beam.
Old 11-14-2012, 04:12 PM
Zydan
Zydan's Avatar
That's something I wish I had done when I had my headlights painted, regrets, regrets!
Old 11-15-2012, 11:10 AM
TruLux
TruLux's Avatar
Can someone answer my question?
Are the lenses the exact same size? a simple swap? or does it require extensive work?
Old 11-15-2012, 11:33 AM
huwee06
huwee06's Avatar
Well it sounds like the 2.5" TSX-R lens are direct swap as the ppl who did the swap put it.
I just want to know how to remove the OEM lens from the housing maybe some pics on how to DIY as I know weiboy mentioned pop the tabs but his pics aren't there anymore MEH
Quick Reply: Clear lens.. Worth it?
