need help with these door sills
i have the illuminated door sill i purchased from ebay with no T harness wire
i got the instructions that require the T harness wire and the instructions is sketchy to me. I contact the dealer for the wire they said they cant get that wire can someone show me how to connect them because i will be cutting wire , pics will be nice if anyone can help
ebay strikes again .... for the life of me I can't understand why folks do it. I know that doesn't help you. I have the sills (bought from Infiniti) and it uses a junction wire harness. I'm not going to open my car up to take a picture and even if I did I think I remember the wires get wrapped in a padded sticky tape. You basically want to tap into your wiring for the door lights. The original drawings/instructions do suck. Having all the parts it still took a while to sort out their instructions .... good luck.
As far as OEM installation no, they junctioned on the passengers side, low, right, under the plastic around your feet. On the side of the car, not the firewall. Then you run the wire to the sills for the driver side behind the center console.
timc00k
02-15-2017 09:15 AM
FlyIce
09-29-2015 04:07 AM
Murkr
09-28-2015 10:45 AM
