Best clear spray paint for taillights?
I used Rustoleums' "paint for plastic" clear on my headlight housings and I ended up redoing them since it caused a kind of dusty mist look over the base coat. Need recommendations for what would be best over painted tailights (and I will be sanding the clear down a bit w/ 1200 grit).
Thanks!
Thanks!
DO NOT use the stuff from Auto Zone it will look like poop in about a year or so. Order a can of Spraymax 2K areosol clear. It has a harder that you have to activate before using it but it's the same stuff body shops spray out of their guns. I used VHT Nite shades and spraymax clear on these tail lights!
Thanks a bunch DwD, just what I was looking for. Is this the same clear that you're talking about?
Spray Max 2K Rapid Cut-In Spot Clearcoat - 3680062
