Help Ballast out
Ballast out
Anybody here know the best way to diagnose headlights? I just noticed coming home that my driver side HID is out.
I replaced the bulb with a known good one and still no go.
Which leads me to think it's the ballast. But before trying to find a new one, i want to be sure.
On that note, is eBay the best place to find a used ballast?
Thanks guys!
p.s. A ballast is a ballast for these cars, right? That is, it won't matter if the car is AFS-equipped or not?
Thanks guys!
Thanks guys!
Thanks guys!
yup, a ballast is a ballast. makes no difference between cars equip with afs or not. also, the ballast for the Z's will work too.
Saffioti (06-16-2024)
Thanks, Weiboy!
Yep, i just tried the OEM bulb which i knew worked. Still no go. The fog/clearance and turn signals all work. It's just the HID that won't turn on.
The fuse for this is behind the battery, right? Would you know offhand what kind? I may just pop by Autozone before heading home tomorrow and get some before tinkering with the fusebox, just so i can fix it right off the bat if it's hopefully just a case of a burnt fuse.
Thanks, Weiboy!
Btw, do you have modded lights or has the car been in a big rain storm before it went out?
Weiboy, looks like you're on to something. The fuses all seem to check out fine so i went ahead and removed the ballast (on a sedan, accessible by removing the wheel well cover).
Lo and behold! The ballast was holding water, it literally spilled. I opened it up and the inside seems to be covered in some type of gel, and was damp. I'm starting to dry it out now and *HOPE* that it works afterwards. Wish me luck!
Good luck Mike and hopefully that is it!
Weiboy, you sir are a genius!
Although i ended up getting $15 worth of fuses, and have committed to buying a spare ballast from a member here, I am so happy and relieved right now! I did use a blow dryer and kept it inside a small ziplock full of silicone beads for a few hours, then took another pass with the blow dryer.
Thank you, thank you, thank you!
If the ballast is cheap enough, won't be a bad idea to have a spare on hand.
^ Indeed! You can't get this kind of help with most service centers.
Just an update. I think my housing may be compromised. This fix worked out fine for a couple of days, now it's out again and there's a lot of large drops of water in the lens housing -- i'm sure the ballast is drowning again.
I am starting to think someone bumped into the housing and cracked it somewhere - it's happened in the past on an old set of headlights. It has been raining a lot again and it just looks like the water is almost literally pouring in. It's not just a thin film of condensation, but actual water droplets.
Hope to just take the headlights out completely on the weekend and assess what the problem is.
Oh yeah! You def need to fix the condensation first or else it will keep happening. Let's say you can't find the crack anywhere my advice is to remove all bulbs, screws and ballast then throw it in the oven and bake it at 250F for 7 mins then compress the housing together and install everything back.
