Debadging questions
On a hot day like 90 + you can just peel it off with your hand or use fishing wire. The heat loosen up the glue if you can pull on the letter and it moves then u can just peel them off after that scrape of the glue with your finger nail or use goo gone that works best or heat up the letters with a blow dryer or heat gun on low setting very easy look good IMO
JG_G37
09-19-2015 09:07 PM
nbast
09-14-2015 12:39 PM
johnadlertech
09-11-2015 02:07 PM
