Amber Fogs
These fog lenses... they aren't crystal clear. They're kind of milky, kind of cloudy. Is it that way for any one else's G? Mine is barely a year old.
Wrapped things up just now (no pun). Pics:
After dark, I took the car out into some lonely, wooded roads. That's a pretty uncommon thing around here, but I know of a few places. There were no other cars, and no other light except my G. To answer Sniper's question, it's still noticeable when the fogs are on, but not so much as to matter... which was about what I expected.
However, getting out of the car and walking down the road a bit and looking back at the G with the fogs on in the pitch black, the aesthetic look was absolutely stunning. Quite a beautiful amber glow.
Two last thoughts: fogs get hot, and I'm concerned about how well the tint will hold up to the heat. And finally, I completely forgot how insanely bright and effective the G's projector HID headlights are. On a dark, wooded road with no other lights except the stars, the G37 will light up the road ahead like a UFO. It's pretty impressive.
Yes. All the bulbs are stock... except the back-up bulbs, the license plate bulbs, and the courtesy door lights.
No, you don't have to remove the bumper.
That's it. The driver's side is a total PITA because of the washer fluid reservoir and the horn. Just bend the horn out of the way. Better yet, start on the passenger side so that you can get a feel for how it works.
- Either take the entire lower engine cover off, or at least the half for the side you're working on. They're all 10mm hex head bolts. (Standard M6x20mm)
- Unbolt the lower corner panel for the side you're working on, and unclip it from the wheel-well. You don't have to remove it, just unclip and unbolt it enough to pull it aside and get your arm in there.
- Remove the fog bulb by twisting it a quarter-turn and pulling, which is much easier than unclipping the harness.
- There are 5 tab-clips holding the black crosshatched panel into the bumper. Push those clips in and work the panel forward out of the bumper. The chrome trim piece can stay clipped to it. No need to remove that.
- There's a single retention bolt for the fog assembly to the bumper. It's a 8mm hex-head. Undo that bolt.
- Remove the fog assembly.
If it goes bad because of heat, then it'll certainly be removed.
And I'll be sure and post back if that happens. Too often people do mods that are the greatest thing since sliced bread, but never follow-up when it doesn't quite turn out that way. So, I'm not proud. If it fails, I'll say so.
But while I'm thinking of it, I happen to have a picture of the car's rear with the LED back-up lights, and the amber-LED license plate bulbs... but before the matte-black vinyl wrap on the bumper.
John, hard to tell for sure from the pics but how far behind the plastic mesh does the entire fog assembly go back? I'm really thinking about purchasing the oem 2011 fogs (since my in-light fogs are now pretty useless since I painted my housing black). If they'll clear my washer tank I may give this a go, shouldn't be to hard to fab from looking at your pics.
Thanks!
Thanks!
Thanks!
Thanks!
You're going to need some pretty good fabrication skills, I think, in order to align them properly. Remember, the fog assembly itself is fitted and bolted into the bumper (by a single bolt). The crosshatched trim and chrome ring are simply clipped into the bumper *around* the fog. Even if you bought the parts, IDK how you're going to fix the fog light in place.
I also imagine OEM foglights from Infiniti will be silly expensive, but that's just a guess.
Here's a thread you'll probably be interested in:
https://www.myg37.com/forums/body-in...it-thread.html
I don't actually know. Had a friend visit from Canada last month who's developed a pretty significant set of skills with lighting; even had a side-business for a while before getting swamped and backing off. You should see the any-colored dashboard he can dial in with a wireless remote into the dashboard of his G35. It's truly impressive.
Anyway, he came down with some gifts, including these back-up bulbs, which was a pretty serious array of LED's. And not your typical ebay crap, either. I know, I've bought LED's off ebay, and there's some garbage out there.
I was hesitant, because I didn't think the light output would be strong enough. But you know? It was! Go figure.
And it's beautiful. Not that I can see it often unless I'm backing up near an office building with lots of glass, but I know it's there.
#30
The reason I ask is because this photo makes your fog light look like one of those nasty butterscotch candies ... swapping the bulb may have more of the "OEM look" you seem to be going after (subtly is key)
