Notices
door handle sanded!
Old 06-22-2012, 11:16 PM
  #31
TwoThree
TwoThree's Avatar
Use a small flat head screw driver. Just be carefull. Some put tape on the screwdriver to prevent scratches. There's a small notch on the underside of the aluminum handle and just pop off the cover and run the screwdriver along the seam. It's really easy to do. Just take your time and don't scratch things up.
Old 06-24-2012, 07:25 PM
  #32
Bad G IPL
Bad G IPL's Avatar
I want that water bottle !!!!!!!
Old 10-05-2012, 04:10 PM
  #33
Kkitten
Kkitten's Avatar
Awesome this is good info... one quick question... the previous owner scratched the panels up along with the shift ****... i love the look is there a way to get the aluminum out of the shift **** on the 08 as well? I need to get her back up to "pristine" condition before i go crazy with the silly little scratches...
... and where do i find one of those water bottles?
Old 10-05-2012, 09:53 PM
  #34
xxg00w0
xxg00w0's Avatar
i think it's better for you to just replace the ****. You can sand the shift ****, but you will need a sanding block for better result.
for the water bottle, it really depends on which dealer you go. some of them has it not some of them they dont..
Old 10-09-2012, 11:57 PM
  #35
revealer
revealer's Avatar
Looks good
timc00k
02-15-2017 09:15 AM
SpeedBallDEVIL
10-02-2015 11:20 PM
Murkr
09-28-2015 10:45 AM
Slapshot1
09-27-2015 08:40 AM
Quick Reply: door handle sanded!
