LED DRL Questions.
I went with the white ones. The link you gave me was the ones I purchased. Ill post some pics when I get em installed. I put new Morimoto 6000k HID bulbs in my G and they are much brighter then stock and looks so much nicer then stock.
Hey, I'm just a little confused and wanted to clarify. The DRLs (if you're Canadian) are H1 bulbs and they're above the parking lights which I believe you're referring to as DRLs. In the pic by TwoThree, the light bulb that is on are the parking lights and the one bulb above it (hidden behind the reflector) are the DRLs.
The DRLs are the ones that are always on when your Bi Xenons arnt on. I live in Canada and the DRLs are on even when you have the fog lights off at nighttime. DRLS are the 194 which is stated above and the H1 are the foglights which are hidden behind the reflector. Correct me if im wrong cause I did a lot of research before making the purchase.
Hmmm... DRLs are suppose to be on when you don't have the beams on and should only be you turn on the fog lights at night. I know they provide less power during the day vs when you have them on at night as fogs. (A lot issues installing HIDs due to this).
So its installed and after the tech gave me the keys I go outside and look and let go the hand brake the lights dont turn on. I have a manual so once the handbrake is released then the DRL is turned on. Nothing is on and I went home just to make sure it wasnt bright out so that I couldnt see and still nothing. My tech had it in but he said it was inserted in to a point where it was kinda loose so he made adjustments to his liking and made it stay in its spot tight. Im gunna get em to check the lights again tomorrow cause he works at my dealership. Was there a issue installing yours?
This thread should help.
Basically there are two ways. Jack the car up and go in through the wheel wells, or remove the air intake box to gain access to the headlamp assembly.
timc00k
02-15-2017 10:15 AM
