one of my headlights wont come on
hi guys i need some help asap as the car is my mothers daily driver. its an 04 g35 coupe that has had the healights converted by the previous owner to 06 lights. just last night one of the lights no longer turns on so the one thing i have done so far is swapped the bulbs from left to right and right to left. well now the light that wasnt turning on comes on, and the one that was working now doesnt since i have switched side. my question is what would be the most likely cause of this problem. ive gone back over and made sure al the connections where tight and plugged correctly. any help is apreciated.
Read what you said earlier:
I think you meant to say: swapped the bulbs from left to right and right to left. well now the bulb that wasnt turning on comes on, and the one that was working now doesnt since i have switched side.
In that case, it could be a blown fuse, bad ballast, shorted wire.
causing, coupe, fuse, g35, g35driver, head, headlight, headlights, headloghts, ignitor, lights, myg37, projectors, turn, wont
