2012 Coupe HID fog lights - need help
Just got done installing. When I turn my car on and the auto lights turn on the HID's dont fire up.. I have to flick the fog light switch on and off a couple times and sometimes only one side will light up.. eventually i can get both to come on and stay on.. Any ideas on what is going on? I hard wired the HID kit to the cars wiring sysytem (eliminating the factory bulb plug) and I used butt connectors and shrink wrapped them. The kit is made by Phillips so its not some crappy hardware.
Also, my drivers side buld is a little bit brighter then the passenger side. Any ideas?
Thanks in advance,
C
Thanks in advance,
C
i had the same problem, and my frd's is250 had this problem too
its because the voltage changed from 55w to 35w; therefore, auto on/off headlight may not turn on both left and right fog in the same time. Just simple switch off and on the fog light will be fix
one side brighter because the ballast or the bulb problem
Thanks in advance,
C
Thanks in advance,
C
Hey thanks so much on your input! You really helped me out! So my bulbs and ballasts are from Philips, but my wires that connect everything were made somewhere else in the world. Oh wait, this didn't solve any of my issues.
Relax man . I have many HID kits on my cars but never power them from factory wires, allways from battery and never have any problems with them. Do You have harness with the kit? if not get one with inline fuse for few $ and use factory wires to just turn them on or off. I hope this help You. You can get harness from www.hidplanet.com.
superjoey
31
03-22-2023 11:56 PM
sydnrusty
11-21-2015 10:42 PM
bikerjosh
08-19-2015 11:26 PM
