Best top coat for painted grill?
Hey guys! I've recently blacked out my grill using Krylon fusion spray paint. To finish it off, I used PPG concept clear coat. After leaving it to dry for an hour or two it just didn't look right. I ended up removing both paint and clear coat. Using PPG concept was way to hard and I wanted to look for a clear coat from a can to make things easier. Any suggestion on which clear coat I should use? I'm looking for a flat black(matte look). Thanks!
Painting with enamel and not putting ANY kind of clear is seriously a wast of time cause that **** will chip wicked quick.
OP...I used rust-o-lium wheel clear. It's good on plastic and metal. It's super tough. You can buy it at autozone for $7 a can.
Good luck!
Btw OP...
https://www.myg37.com/forums/picture...my-grille.html
I used his supplies and his procedure and my grille came out awesome.
Check it out.
Check it out.
I believe they also sell a flat clear coat for that matte finish.
Good luck!
Good luck!
cconklin2
01-09-2016 07:21 PM
