Help LED signal lights is blinking fast for G37
Old 02-18-2012 | 05:18 AM
the dreame's Avatar
the dreame
Hello all
I bought front, rear and side signal LED bulbs for my G37 sedan 2009. When I installed the front and rear LED lights I think 7440 it was blinking very fast, after that I returned the old one and worked fine.
How can I use the new LED bulbs as normal blinking like the original
The buyer told me to install a 6 Ohm, 50 Watt load resistor for each signal light so it will cost me more and it’s not easy to install and find a place to hold this resistor
My side signal light is on the fender between the front tire and front door, the problem that I can’t open the signal light unit to replace the bulb with LED that I bought from superbrightleds.
Any ideas or suggestions
Old 02-18-2012 | 06:57 AM
Mysticalism's Avatar
Mysticalism
Originally Posted by the dreame
Hello all
yeah, too much voltage going through that lightbulb. i wonder why superbightled didn't give you one that accepts the right voltage...
the dreame (07-04-2013)
Old 02-18-2012 | 09:26 AM
This is what LEDs do when placed in locations designed for regular turn signal bulbs. They're working like they're supposed to. The LEDs make the car think the bulb is blown and they hyperblink to indicate that. Install the load resistors or put in the bulbs that are designed for the socket. Those are your choices. Either that or learn to live with the hyperblinking.
Old 02-18-2012 | 08:09 PM
dtran2714's Avatar
dtran2714
^^ I 2nd that
Old 02-21-2012 | 01:18 AM
the dreame's Avatar
the dreame
before i order my LED's i read
Your vehicle may require an LED compatible Flasher or Load Resistor
if i know that my car need it, i will not order LED signals because i wanted plug and play without any modification
Old 02-21-2012 | 01:48 AM
sniper27's Avatar
sniper27
what so hard about installing load resistors?
Old 02-21-2012 | 08:40 AM
Rad_Slinger's Avatar
Rad_Slinger
^^ya, it's really not that hard. I wouldn't call resistors "modification". They are pretty much plug and play.
Old 02-21-2012 | 12:15 PM
jhenka's Avatar
jhenka
If you have Led's for the front AND back turn Signals get this
3 OHM 50W 4 BULB LOAD EQUALIZER RESISTORS LED TURN SIGNAL BLINKER FIX | 1 PAIR
If you have leds for the front leds ONLY get this
6 OHM 50W 2 BULB LOAD EQUALIZER RESISTORS LED TURN SIGNAL BLINKER FIX | 1 PAIR
Old 02-27-2012 | 06:29 AM
the dreame's Avatar
the dreame
i don't know what is flasher and see it before so that am afraid to put it in my car for warranty purpose
Old 02-27-2012 | 07:51 AM
the dreame's Avatar
the dreame
when i push the hazard botton it will work OK, but when i right or left signal it will flash very fast
Old 02-27-2012 | 02:50 PM
sniper27's Avatar
sniper27
that's normal. just put some load resistors on and call it a day. takes 5 minutes or less.
Old 03-03-2012 | 08:19 AM
the dreame's Avatar
the dreame
Hello all
How to do it and should i install a resistor for it also
Old 03-04-2012 | 02:17 AM
sniper27's Avatar
sniper27
where are you from? are you talking about side markers on your fender?
Old 03-04-2012 | 03:58 AM
the dreame's Avatar
the dreame
Yes, and look like this
Old 03-07-2012 | 06:23 AM
the dreame's Avatar
the dreame
