HID Reverse Lights Finally Available!!
Mods rip my head off I wasn't sure were to post this so please relocate accordingly.
As some of you may know I spent the past year or so working with my asian distributer finalizing a safe, plug and play, HiD reverse light solution. I have tried everything from filament bulbs, to leds, to hids. You can see more about that in my reverse light thread.
https://www.myg37.com/forums/g37-sed...-question.html
The problems I encountered (aside from melting housings, bulbs not fitting, $$$ spent on the most expensive LEDs money can buy) was that my reverse lights still WEREN’T bright enough!
Over the past year I tested different ballast, installation systems, bulbs, bulb/ ballast wattage, plug and play wiring etc. A few things that were vital for this project to work were: the bulb had to make an airtight seal, the wiring had to be foolproof, and the bulb had to last under heavy abuse. Also did I forget to mention these bulbs burn cooler than some high-powered LEDs? After finding the exact combination, I started working on the next step. Working closely with my distributor we coded the ballast to hit Full Brightness in LESS than 2 seconds, and have an auto shut off of 30 min to protect the housing from any possible damage. After everything was finalized and the kits were ready to ship, I still wasn’t quite ready to release them yet. It took me 3 months testing before I could finally make them available. I had to make sure the quality lasted and the bulbs / housing were in great shape.
Without further ado I present you the HID Backup lights.
Sorry about the ****ty video been really busy lately will try to get more videos and pics up shortly.
<iframe width="420" height="315" src="http://www.youtube.com/embed/6EdnXqk_OYM" frameborder="0" allowfullscreen></iframe>
If you want the exact specs of the bulbs and ballasts I can post it up.
I will do an initial group buy for the first 15 people. After that each kit will be sold at full price.
1. JSolo
2. LookingToBuy
3. tekie99
4. Spingjp
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
edit:
These kits are universal, You can put them in virtually any car. No need to specify sedan/coupe g35,37 etc.
1. JSolo
2. LookingToBuy
3. tekie99
4. Spingjp
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
edit:
