Help Hoen H8 Endurance bulb pair 35w
Höen Endurance Fog Light Bulbs
The Endurance line is similar in appearance to the lighting used in Endurance motor sports such as the ALMS and 24 Heurs du Mans. We recommend this bulb for fog lamp use only! It is very, very yellow in color.
The Endurance bulb pair is priced at $39 per pair and ships in factory wattage requirements.
thank you sir.....ordered them. Will attempt to install. They were easy peasy on 2009 AUDI A4. I am hoping for the same here.
In my experience, VW/Audi is way easier to mod. I used to remove the grill off my MK4 jetta in 5 min with 5 bolts. It seems everything on the G requires you to remove so much more stuff and is hard to get to. meh.
