LED Clearance Light Issue
Hey guys, just recently got my LED's from Diode Dynamics and replaced all the dull yellow bulbs. All was great for couple days, except when I got home earlier noticed 'clearance' (daylight) 194 led's flickering. This was after engine was shut off with lights set to 'Auto'. I tried to start the engine but this persisted. Can someone please let me know if I'm missing a resister/capacitor perhaps? Any write up on what to get and how to install would be greatly appreciated.
I will do that later today but I doubt that's the issue. Both right and left is doing the same thing which leads me to believe it's either faulty LED's, or something is going on with the module itself. Will update tomorrow.
It's not faulty LED, At least IMO, All most all of mine did that when I first put them in,. I had to recheck the connection wires when installing them. Just had to fix one of my DRL LED last week. It would only light up after 5-10 mins( I think) I took it out messed with the wires and put it back in.. I still now and them have to tap my map lights because on of them doesnt always come on.. its just the connection wires are so thin.. .:/
Doubt it would be the wires, it works just fine with OEM bulbs. It might be due to lower voltage requirement of LED's. I will try to get my hands on some LED conversion resistors that might fix this. Strange that it's an intermittent issue in some places but not others.
I have replaced every 194 bulb in my IPL with LED's and have not experience any flickering. I have also installed LED's on several other sedans and coupes without issue. What do your LED's look like? It could be a faulty led driver. Generally LED's use an IC chip to pulse the diode around 100HZ, if for some reason that IC is bad it might be pulsing at a lower frequency that will cause the pulses to be visible.
Thanks everyone for the input. I've been really busy last week, didn't have time to go on the forums. It's a PITA alright, they couldn't of made it any harder to replace. After pulling out the LED's I noticed they look nothing like the ones I got from Diode Dynamics, the kid at the shop must of confused them with the ones I told him to put in (they were in same bag). Going on 6th day now with no issues. Just realized I got those LED's at Advance Auto Parts for $10. What a rip off.
You've been really helpful, thanks man Glad to have this issue handled. Can definitely see the difference between junk and quality bulbs.
superjoey
31
03-22-2023 11:56 PM
maybeg37
09-08-2015 02:33 PM
