hell every body.i`m new comer.
just ask some questions....
how to make screen show this?~!
and i got 2008 red g37s what color body kits i should use.
some body can show me the pic for the red g37 already modify the car,
thanks
thanks
That screen is with HKS F-CON ecu i believe, so goodluck
Red car huh? maybe try a red body kit i hear Extreme Dimensions has good stuff
And heres a red modified G37 coupe, heres Stoofs incase youve never seen it
that is the Blitz monitoring system that connects to your factory screen. why do you want it for anyway? unless you're planning on going forced induction otherwise it's pretty much useless.
this one is the HKS CAMP 2
I would get it if only it didn't cost too much just for shiz and giggles.
Oil Temp: either you add a oil pan spacer or drill through your upper oil pan.
Oil Pressure: buy a adapter from GTM and tap it into the stock oil pressure sensor
Boost: any VAC hose
EGT: on the headers
Water sensor: drill and tap the sensor right below the radiator cap
Fuel Pressure: will need a adapter from GTM and tap on the fuel line that's on the engine bay.
