Disconnected the battery and now the drivers window won't stay up
I disconnected the battery so that I could remove my steering wheel in order to get to the bezel out and I'm having some problems. I re-connected the battery and noticed my window was down 3/4 of the way. So i tried to raise it and it wouldn't go up with the car in KOEO (key on engine off) mode. So I started the car, and closed the door and the window goes all the way up. As soon as I shut the engine off and open the door....window goes almost completely down. Does anyone know how to fix this?
Also, I couldn't get that T-30 Torx screw out of the steering wheel to take the airbag out so I could get to the bezel. Does anyone know what thread and length it is? I'm planning on using a screw extractor to get it out now, and I'm gunna have to replace it with something.
Here is what I used
Problem with Power Windows after battery disconnect. (Solution) - FreshAlloy.com Forums
As for the screw, your best bet is to take it out and go to the hardware store
Does anyone read the manual anymore?
SuicidalG37SGuy
09-10-2015 06:01 AM
