Phillips Ultinon
Here is a G37 with them.
OSRAM CBI 5000k - G35 NYC
Thread on Hidplanet with lots of pics.
New osram D2S bulb Xenarc "cool blue intense" must see
The seller canceled my order because I never use ebay. Thank god he did: HID Legitimacy these lights look to be fake.
Yup, I have them on my car. They are white, no hint of blue or yellow, and just as bright as stock if not brighter.
with my morimotos, the high beams suck.
Just installed mine this evening. Even if these are knockoffs, they have very solid construction, and fantastic output. I have them installed next to my 6000k switchback markers, and there's no difference in color temp. Very noticeable increase in lumens going down the highway, and I love the slight bluish tinge.
From what I can tell, they may be the real deal. I'm about 90% certain that they are. They are Japan market, the packaging matches exactly what Japan market is getting from catalog shots I've seen. Same coding on the bases, same squared off UV shielding, same 90deg bent, blue shielded, earth rods. Salts are harder to tell, because any photos I've seen - half are red, half are not, and the majority of those I've seen from the JDM catalogs show non-red salts. As I had said: if they are knock offs, they're damn fine quality, and better than some of the crap other ones I've seen. How they'll last...time will tell.
another alternative is the rare Philips 85122CM, CM meaning color match which rates the bulb at 5000K. I had that bulb, it was great on my G35 coupe projector however really poor in my G37 projector which I ended up swapping back to the stock bulbs. In the end as stated, nothing beats the performance longevity of the Philips 85122+ (4300K) enough said...
#29
B Feelgood
09-13-2015 05:56 PM
Mike S.
01-17-2014 02:16 PM
Fire0nIc3
05-08-2010 10:24 PM
