Plastidip Cutting Help
I used plastidip for the first time on my grill yesterday with mixed results. Came out nice in the middle but I had a problem with a precise cut when I removed the masking tape. I also want to do the valence but what is everyone using to get a clean edge? I feel like using an exacto knife will scratch the paint.
I just dipped my front grille this weekend... I taped off the top bar and the lower bar, sprayed it black in the middle. I just used a razor blade and very lightly followed the line of the painters tape where I needed the seam to break. Came off without an issue and turned out quite well.
I put on about 4 coats of plasti-dip, so it was on their pretty thick. And I said "lightly", really you just run the blade along the tape line without applying any real pressure to it. Didn't scratch anything. I'd post pics, but I'm at work, no camera and no photobucket account =P
Call me crazy but you think if you ripped off the tape immediately, before it dries, that it wont pull? Ofcourse you'd have to retape for everycoat, but if you tape it, spray it quickly, then rip the tape off then maybe that could work? I'm going to have to do a little experimenting, with everything above.
Or just peel from the side of the tape that the plasti-dip is closest to. I did zero cutting to get a clean line, just peeled from the side that's not obviously going to pull the coating up.
It's science.
It's science.
I took my grille out to Plasti-dip it. It has perfectly clean lines and it was far easier than painting it. It's not necessarily a matter of laziness though, it's a matter of "do I want to keep it this way?".
Also, grille. A grill is what you cook your burgers on.
F@ck. I knew someone was gonna say that. I have to look for them, I posted pics of my progress when I was doing it over on Driver, I'll repost them here so you guys can see how I did it.
