Where to buy LED to mod headlights
Ok so i just bought a G37 and i had a g35 before and i modded my headlights and everything came out really good im kind of good doing craftman jobs
my question is where can i buy the LEDs to put on the projector bezzel shrouds ?
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
You will get a lot of responses but the majority of folks (self included) highly recommend v-leds.com as previous person said.
i just got the biggest headache going through all of the items and i cant seem to find which model of bulbs are used to install them on the headlights similar like ONEighty does them
one one has any idea which LED's are used to put behind the bezel shroud?
would these work?
AE series Angel Eye Headlight Accent Lights Specifications
would these work?
are you looking for smd leds?
http://www.lc-led.com/Products/department/48
I haven't try these out myself but I would buy a few and test it to see how reliable they are.
Power SMD LED
Power SMD LED
I just spent $80 and bought 20 high powered LEDs. I know they are expensive but I'm hoping they'll last forever. I'm going to try and wire/install them to the reflective plate in the headlight. I also bought the plastic holders. I've tried to contact 180 and MrWorks and have had ZERO luck.. so I'm going to try it myself. I don't think installing the LED's in the reflective plate will be that hard. lol. Unless the dam reflective plate cracks.. Then I might be in some trouble! Does anyone know if that's what the above companies are doing? or are they replacing the plate with some other type of material and then installing the LEDs? Either way I'm going to figure it out. I've been wanting to paint the interior portion of the headlight anyway. Wish me luck.
10mm LED high power
10mm LED high power
this is what i ended up buying 72$ Wired LED Specifications hope they fit/work
