Yellow fogs
#32
So does Nokya even make a 55w?
I'm trying to find an H1 for my 08 coupe and all i can find is their 70W
NOKYA Hyper Yellow Light Bulbs (H1)|NOKYA JDM Yellow Light Bulb|NOKYA Pro-Halogen Light Bulbs
#33
CLARIFICATION PER THE MANUAL; 2010 - 2011
SEDAN FOG LIGHTS - H8 (35w)
COUPE FOG LIGHTS - H11 (55w)
This is regardless of sport/non-sport. I will also inform you that H8 & H11 bulbs are the exact same size/housing/etc. The ONLY difference is the wattage.
***CORRECTION - The H11 has one pin that is slightly larger. Conflicting information says some still fit, some manufacturers make the pins the same, etc.
...now the question is - do you think the coupe uses a different harness or housing? Or can we sedan guys get the H11 for a brighter fog?
***OBVIOUSLY - The actual connector is going to be a tad different due to the correction above, but question remains the same granted they fit with minor adjustment. Is the wire gauge different to support the H11's? Or are they the same and we can do it on the sedan?
I have a 2010 Sport Coupe, and no way will H11s fit in there.
I just changed them, and used PIAA H1s.
#34
Use these, yes they are more expensive, but PIAA is a top brand.
55W = 110W Meaning they are 55w with the brightness of 110W
PIAA Plasma Ion Yellow (H1) Halogen Light Bulbs|PIAA Light Bulbs|PIAA High Output Automotive Light Bulb
