So, as some of you may recall may car would continue to die as the radio would somehow stay on and I would always lose power. Today same thing happened, but i realized my driver side carpet was SOAKED! today it rained in the north east, but i did not leave anything open, so i started looking and under the carpet found the entire car FILLED with water, my fuse box was literally dripping water!! What happend was the grommet where the power cable for the Amp goes through must have moved so all the water that runs down the car was running into it! Luckily it seems the problem is fixed, Im running the heater in the car for all the water to dry up. So just be careful when you wire things that you CLOSE the GROMMETS
