2011 G37S coupe complete lighting upgrade (pics inside)
#42
I just got the same car today.. MLW g37xS.. The fogs on the bottem I would liek to change..
-5000k H11 slim ballast HID drop in kit (set)
V-HID 35W SLIM BALLAST XENON HEADLIGHT KIT H11
Was that kit easy to install? Anything major? You changed you HID headlights low/high beams? if you didnt would the stock headlights match the H11 kit at 5000k?
Thanks
Thanks
#43
Thanks
Thanks
easy install for fogs, once you remove the fender liners, its all clear view of the fog light housing. very very easy.
regarding the low/high beams, i changed the bulbs to get a dead on exact color match with the fogs.
the oem low/high beam HID bulbs are a lower temp bulb, im thinking 4300k as opposed to 5000k so it emits a slightly different more yellow color.
#45
Nice work bro, it looks amazing!
Where exactly did you mount the ballasts? Is it safe to mount HIDs in such a small fog housing? Overheating? Housing melting?
Also, how did you seal it so moisture does not get into the housing?
Regards,
Tony
Regards,
Tony
