How To Change Fog Light Bulbs G37s
I just got a 2011 G37s 4 door and i want to change my stock fog lights to 6000k hids i already got the kit. What is the best way to get them change or is there a how to guide i can go by
the left fog light is easy to change the right one has the window washer fluid blocking look around in the forum
G-DOG
Best way to get to the fog lights is by removing the right & left sides of the splash shield under the car.
See: "Changing fog bulbs"
I've been trying to search the forum but I can't find how to do the right fog light. Like you said the left was easy and the right has the fluid in the way. Help!
OK, I just did this exact swap a few weeks back. It is very very simple. Go through the wheel well on the driver side, and just peel it back. For the passenger just go through the bottom of the car. I didn't jack my car up or anything. Just lay on the ground undo a few bolts and that's it. It's a little tighter getting everything through the passenger side but you can do it. This is very very easy.
abrecos (05-23-2020)
superjoey
31
03-22-2023 11:56 PM
bikerjosh
08-19-2015 11:26 PM
