Do i need to buy ballast also along with new d2S and h1 bulbs?
Old 01-19-2011 | 05:33 PM
Nautic6's Avatar
Nautic6
My friend told me i don't need any ballast because there are already ballasts with the original lights. I want to do the correct thing and not have my bulb burnt out. Advice needed. Thanks.
Old 01-19-2011 | 05:48 PM
Weiboy718's Avatar
Weiboy718
You're good, just change the bulb
Old 01-19-2011 | 06:08 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
+1, should be fine
Old 01-19-2011 | 06:39 PM
GraphiteG37S's Avatar
GraphiteG37S
Yep, our cars already come from factory with HID ballasts.
Old 01-19-2011 | 06:52 PM
Nautic6's Avatar
Nautic6
Thanks fellas
Old 01-19-2011 | 07:23 PM
ONEighty's Avatar
ONEighty
Well if you're getting an H1 HID bulb, then you'll need the entire HID kit. For the low beam (D2S) all you need to do is swap the bulb w/ the existing one.
When installing H1 HID kit, its easier to remove the headlight so you have more room to play with, otherwise you risk breaking the socket which the clip goes into to secure the bulb in place, it's a very tight fit with most aftermarket bulbs so be careful when pushing that clip back in place.
Old 01-20-2011 | 07:29 PM
Nautic6's Avatar
Nautic6
thanks 180
e92ry
12-31-2015 09:02 PM
mahadeod
10-06-2015 02:02 PM
Flakman
09-14-2015 09:36 PM
pauliewalnutzz
09-08-2015 12:41 PM
dlc1988
09-02-2015 10:40 AM
