G 37 Sedan fog light replacement
Headlights yes.
Fog light on drivers side yes.
Fog light on passenger side may require removing the plastic splash plate underneath the car to get more clearance. The washer fluid reservoir is definitely in the way on the passenger side so you can't go through the passenger wheel well for the fog light.
if you need to change out the fog light assembly since you have a cracked lense, you will be able to gain access thru the wheel well also. is your car lowered AND on 20's? It might be better to remove your wheels if you don't feel comfortable taking off your bumper.
Come to think of it, I had a cracked fog light lense on my M35, luckily I found out that the Nissan Sentra fog light assembly was a direct fit - saved a ton of money getting a set on eBay....not sure if the G37 is the same way...
superjoey
31
03-23-2023 12:56 AM
sydnrusty
11-21-2015 11:42 PM
bikerjosh
08-20-2015 12:26 AM
