Volt/oil pressure gauges?
My father has a 370z, and though i know they arent necessary, i feel more comfortable knowing everything thats going on in my engine. Does anyone know where a good place would be to get an oil pressure/volt gauges and how to install them?
Thanks!
Thanks!
let me know if you more help with the parts cuz it's not that simple to install as some people think.
Sure! That is if you can find a pillar pod. There is none available for our car's atm.
Has anybody in here installed the volt, temp, and pressure gauges ??(except showcars)
I don't remember seeing it done yet.
Don't they have those universal pods that goes on top of the dash? Or those gauges that screws directly onto wherever you want to place them. (no need for a pod)
i don't think anybody has tried to install the gauge pods.
"Or those gauges that screws directly onto wherever you want to place them. (no need for a pod)"
Those are the ones im talking about. What exactly is a "pillar rod". I cant just feel whatever wires i need down the A-pilar into the engine bay. The LCD is awesome btw. But i like real gauges . Which are also cheaper
http://www.defi-shop.com/product/rg/rg_top.html
i thought about going this route in the beginning. looks cool as fvck. these are not cheap tho lol. good luck to whatever you're planning on doing.
like this?
Defi - Racer Gauge
Defi - Racer Gauge
for the gauges you most likely will need to purchase the sending unit along with the gauges in order to work. for example: the oil temp sensor you'll have to either tap it onto the engine block or oil pan spacer. i chose the oil pan spacer route as i'm no pro to tap it on the block lol. the oil pressure is an easier one. you can buy a oil sender adapter and install that on the oem oil pressure sensor location.
if you're N/A i personally feel that you won't need all that gadgets. the cost will add up.
yeah im gonna go with oil pressure and volt, which i dont foresee being to hard, i just dont know how to thread the wire through into the engine bay, and where exactly to mount on the a pillar as i have no idea where our air bag is. If we can figure it out how to run a wire, and how to mount the gauges on the a pillar, ill do a DIY.
let me know when you're ready to do it. i can guide you on that.
okay, im looking ive sent an email to THmotorsport about getting a STRI volt and pressure gauge, im sure they will reply tomorrow. So ill order them this week, ill probably go for the non stepper motor, 69 bucks a gauge isnt bad.
"you can buy a oil sender adapter and install that on the oem oil pressure sensor location. " Could you explain that a bit? Im a bit of a noob when it comes to car modding. How exactly would i do that?
GTM Motorsports**ENGINE EXTERNALS**OIL SENDER ADAPTER KIT
send me the link of the gauge you're about to buy. let me check it out for ya
no! i'm sure he knows about it.
