Help Rear LED Turning Signal Lights?
If your are doing 2 bulbs you need a 6ohm resister if your doing both front and back (4 bulbs) than its 3 ohm.
6ohm
6 OHM 50W 2 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
3ohm
3 OHM 50W 4 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX
6ohm
3ohm
here is the thread i started and has some pics at the end.
https://www.myg37.com/forums/body-in...rn-signal.html
I've checked rubber and plastic around that location and so far its been good.(no melting)
If you want reliable operation (that is, without any chance of hyper blinking), you should use a 6 Ohm resistor on EVERY bulb. I tried using only one resistor per side and although it worked for a little while, the hyperflashing eventually started occuring. YMMV, but you're better off doing the job right from the beginning
Are you saying the 3 ohms is not as reliable? and they will eventually return to hyperblinking state again?
Mine hasn't hyperblinked at all since i installed the load resistors.
Maybe the connections came lose.
i'm saying you cannot compare your normal blink rate to another car's normal blink rate, as they will always be different. you mentioned that your blinkers are faster than other cars on the road, but not near hyperblinking. so you need to compare your blink rate now to how it was before the LEDs and resistors, not to other cars. i have not used the 3ohms resistors, but i haven't had any issues with my 6 ohms for the last 8 months.
Bumping this one....
Installing LED's on rear turn signals... where do you mount the resistors? There's clearly no room between the tail light assy and the body. Someplace in the trunk?
maybeg37
09-08-2015 02:33 PM
