Replacement of rear tail light - question
I got a small chip on my rear tail light and was curious how involved of a process it is to remove and replace the light housing and lens. Thanks in advance.
I don't think you can just replace the lens, you'd have to replace the entire light, which is pretty easy to remove.
Take off the plastic trunk lining behind the tail lights (clips) to expose the back the lights. There are I think 3 screws. Once you take those off, the light can come out.
__________________
__________________
Here's what you need: https://www.myg37.com/forums/d-i-y-i...aillights.html
Thanks
This helps, thanks - I couldn't find that in the search.
One other quick question - If I'm just replacing just the lens and housing, do I just have to remove the back of the light with the bulbs and then attach that to the new housing (so the bulbs don't have to be removed)?
Chris Olson
03-28-2024 09:46 AM
bikerjosh
08-19-2015 11:26 PM
arizona, coupe, disassembly, g37, graphite, housing, infiniti, light, myg37, rear, removal, replace, replacement, scottsdale, tail
