I-key windows up?
I-key windows up?
Sorry if this has come up before but couldn't find an answer after searching. I know while holding down the unlock button on the I-key the windows will all open and inserting the physical key and turning to open or lock you can open and close the windows.. but can you close the windows while holding down the lock button on the I-key or is this disabled as a safety feature? Wasn't certain if there were conditions involved like the engine had to be running prior or a specific time after closing the doors? Or I had to click my heels together 3 times!
As far as I know from the manual and some past threads here there isn't any way to put the windows up with a button on the keyfob.
Edit: Apparently there's an aftermarket solution of some sort:
https://www.myg37.com/forums/g37-cou...ng-keyfob.html
RexHavoc
10-02-2015 11:47 AM
CiViCKiDD
09-24-2015 10:47 AM
