Well, I started this morning, about AM, took nearly 10 hours. I 'm quite pleased with the outcome. Did the lights, brake vents, some bulb changes and added 15mm spacers to the front. The tricky part was the rt side but I was able to heat the washer tank and re shape the front lower half to accommodate the necessary space, basically heated with a heat gun then stepped on it and held it down while I cooled it with a hose! Whatever works right? Anyways here are some pics...
