disable remote auto window down, etc. using consult III
Old 05-27-2010 | 01:00 PM
tbear's Avatar
tbear
I had trouble finding this info via search for my soon to be delivered G so I thought I would post it here for others. The dealer can disable the auto window down feature to avoid accidental window down operation when your remote button is pushed while in your pocket and you are out of the car. They can do the same for trunk release or change it to require 2 button pushes.
Here is the full list of those and similar functions they can change with the Consult III on a 2010:
DIAGNOSIS SYSTEM (BCM)
AUTO LOCK SET
Auto door lock time can be changed in this mode.
• MODE 1: 1 minute
• MODE 2: 5 minutes
• MODE 3: 30 seconds
• MODE 4: 2 minutes
LOCK/UNLOCK BY I-KEY
Door lock/unlock function by door request switch (driver side and passenger side) mode can
be changed to operate (ON) or not operate (OFF) in this mode.
ENGINE START BY I-KEY
Engine start function mode can be changed to operate (ON) or not operate (OFF) with this
mode.
TRUNK/GLASS HATCH OPEN
Buzzer reminder function mode by trunk opener request switch can be changed to operate
(ON) or not operate (OFF) with this mode.
PANIC ALARM SET
Panic alarm button pressing time on Intelligent Key remote control button can be selected from
the following with this mode.
• MODE 1: 0.5 sec.
• MODE 2: Non-operation
• MODE 3: 1.5 sec.
PW DOWN SET
Unlock button pressing time on Intelligent Key button can be selected from the following with
this mode.
• MODE 1: 3 sec.
• MODE 3: 5 sec.
TRUNK OPEN DELAY
Trunk button pressing on Intelligent Key button can be selected as per the following in this
mode.
• MODE 1: Press and hold
• MODE 2: Press twice
• MODE 3: Press and hold, or press twice
LO- BATT OF KEY FOB WARN
Intelligent Key low battery warning mode can be changed to operate (ON) or not operate
ANTI KEY LOCK IN FUNCTI
Key reminder function mode can be changed to operate (ON) or not operate (OFF) with this
mode.
HAZARD ANSWER BACK
Hazard reminder function mode can be selected from the following with this mode.
• LOCK ONLY: Door lock operation only
• UNLOCK ONLY: Door unlock operation only
• LOCK/UNLOCK: Lock/unlock operation
• OFF: Non-operation
ANS BACK I-KEY LOCK
Buzzer reminder function (lock operation) mode by door request switch (driver side and passenger
side) can be selected from the following with this mode.
• Horn chirp: Sound horn
• Buzzer: Sound Intelligent Key warning buzzer
ANS BACK I-KEY UNLOCK
Buzzer reminder function (unlock operation) mode by door request switch can be changed to
operate (ON) or not operate (OFF) with this mode.
SHORT CRANKING OUTPUT
Starter motor can operate during the times below.
• 70 msec
• 100 msec
• 200 msec
INSIDE ANT DIAGNOSIS This function allows inside key antenna self-diagnosis.
HORN WITH KEYLESS LOCK
Horn reminder function mode by Intelligent Key button can be changed to operate (ON) or not
Old 05-27-2010 | 01:13 PM
Very interesting information. Thanks for sharing it.
Is this specific to the sedan only or does it also apply to the coupe?
Old 05-27-2010 | 01:22 PM
tbear's Avatar
tbear
Don't know, I would think it would be the same since according to my google searching various Nissan's can be set this way. Posted info is from the 2010 sedan service manual. The service manuals CDs are very inexpensive on ebay and filled with useful info even if you never turn a wrench yourself. Interesting that this problem of windows going down due to the remote date back 8 years or so! My Audi had this feature as well as trunk open, windows up and panic alarm, but the buttons were flush and required substantial force to actuate. I'm disappointed in Nissan's indifference to this problem, there are hundreds of posts over many years from Nissan and Infiniti owners with ruined electronics and interiors due to rain/snow damage when the remotes malfunctioned or "pocket dialed"
Old 05-27-2010 | 03:16 PM
movinon's Avatar
movinon
Thanks for the information.
Whenever I take the car back to the dealer, I'll ask to have the trunk and window down function locked out, on the smart key.
I keep the key in my pocket and use the buttons on the car, so I don't need or will miss these functions.
Old 05-27-2010 | 03:22 PM
tbear's Avatar
tbear
just to clarify, they don't do anything to the smart key itself
Per the service manual, the dealer hooks up to the car with the consult 3 and changes the "modes" for remote windows down and trunk unlock.
Old 05-27-2010 | 04:53 PM
movinon's Avatar
movinon
I wonder if they do that for a courtesy or do they charge for it?
Old 05-27-2010 | 07:03 PM
tbear's Avatar
tbear
Don't know, suspect it varies by dealer. It does take time and someone has to pay the technician. I plan to get it done during the pre-delivery service.
Old 05-27-2010 | 08:35 PM
carz's Avatar
carz
thanks for that info
suggestion, if you can please space out the items a little better so that we can clearly see what the steps are for each item
Old 05-27-2010 | 09:04 PM
tbear's Avatar
tbear
spaces
Sorry it is a cut and past from the service manual and the formatting was messed up in the process. The ALL CAPS lines are sections. I'll try to post again as a scan or an attachment later.
Old 05-28-2010 | 02:31 PM
CGAR's Avatar
CGAR
Most dealers will charge for this option as it does take a while to reset. But if they want any more than a half an hour (about $60 depending on the going labor rate) to do it go somewhere else.
Old 07-07-2010 | 11:07 PM
tbear's Avatar
tbear
Just wanted to confirm that the dealer can do this. I had it done for free as part of my new car prep.
Old 07-09-2010 | 09:27 AM
Master Chief's Avatar
Master Chief
I notice it say "ENGINE START BY I-KEY".
Does this mean our vehicles all have this functionality?
Old 07-09-2010 | 11:24 PM
Rizzo's Avatar
Rizzo
If the battery in the I-key is low or dead.. you can open the door with the hidden physical key and plug the I-key in just below the trunk release button. Pretty sure this is what in means by "Start Engine By I-Key". Am I following you on this question? It's not like we can push any buttons on the I-key to start the engine.. correct?
Old 07-10-2010 | 10:12 PM
Master Chief
I was hoping that it meant remote engine start. I knew it was wishful thinking as there have been posts about Infiniti wanting to charge $500-$700 for this functionality.
vamarris
12-09-2018 12:10 PM
Rybitron
11-18-2015 04:11 PM
delfinparis
10-08-2015 07:06 PM
RexHavoc
10-02-2015 12:47 PM
BurtoN86
09-30-2015 04:32 AM
