headlight wouldn't turn off automatically
Hi, everyone,
my G37 doesn't turn off the headlights automatically when the engine is turned off. I already set the Setting/Comfort/Auto Headlight Off Timer to 0.
Year: 2010
Light ****: Auto
I want the headlights to be off as soon as the engine is turned off to save on the battery. Is there anything else I need to configure?
Thanks!
alex
Year: 2010
Light ****: Auto
Thanks!
alex
It's not entirely clear in the manual, but this paragraph on page 2-33 makes me think the "0" setting might turn the timer off:
You can adjust the period of the automatic
headlights off delay from 0 seconds (OFF) to 180
seconds. The factory default setting is 45 sec-
onds.
Perhaps try the next-lowest setting?
onds.
Even with it set to 0 seconds, the headlights don't normally turn off until the driver side door is opened and closed. Do they turn off when you close the door after shutting off the engine? If so, this is normal.
Yes the way to adjust it is to go into settings -> comfort and convince then I believe you can adjust it in 15 second increments.
Riley (11-27-2013)
auto, automatic, automatically, delay, g35drivercom, g37, headlight, headlights, lights, set, setting, shut, turn, turning, turnoff
