Notices
Just did LED Upgrade-What I Used (FYI)
Old 08-22-2010, 11:46 AM
  #106
TONY37X
TONY37X's Avatar
Originally Posted by Creepers
^^ wow that's farking hawt! it's so bright it wipes out the license plate!
do they make that with a slight bluish tint? i love the intensity but want a bluish LED color...
The lights did some of the work, I edited out the rest of the plate They do have a slight blue tint in some angles and times of day, for example these are the same LED's in my marker lights and for whatever reason they look much more blue.
Guess the imaging of the camera might change a bit due to the low light as well
Old 08-22-2010, 02:35 PM
  #107
Creepers
Creepers's Avatar
wow youre right. im not a camera geek but im guessing the color change comes from a different wavelength, which probably happened when the light traveled through the plastic encasing.
so for $40 i can get the same effect...? im thinking i will go ahead and splurge. for the license plate ive gone through 4 bulbs already, as 2 of them burnt out. hopefully these nicer, more expensive bulbs have some staying power.
thx for taking those pics, tony.
Old 08-22-2010, 02:47 PM
  #108
TONY37X
TONY37X's Avatar
Yup, $20 a pair in either 5000k or 6000k. Look for coupon codes they send out on their facebook page once in a while up to 20% off that ive used and seen, could save you a bunch of money if you are ordering other items as well.
Old 08-22-2010, 05:53 PM
  #109
Namir
Namir's Avatar
Mine were 5SMT 6K bulbs for 9 bucks a pair (more than bright enough for a license plate, I don't get why people are talking about high power). They definitely have a blueish tint that varies quite a bit in pictures. However here is one I took that I feel pretty closely represents how they look in real life
Old 08-23-2010, 04:45 PM
  #110
dainjarouz
dainjarouz's Avatar
I have the same ones...and they dont look blue-ish at all...they probably sent me 5000K..still looks better than stock though.
Old 08-26-2010, 07:50 PM
  #111
CDONNS
CDONNS's Avatar
Just picked up 3 sets of the 5K for doors, maps, and plates...can't wait. Used NVMOTIV for 15% off too!
Old 09-04-2010, 08:59 PM
  #112
TONY37X
TONY37X's Avatar
*** UPDATE *** I Decided to swap my interior LEDS once again from v-leds.com 5K SMT HIGH POWER LED LIGHT BULBS to the 6K WHITE SMT X5 HIGH POWER LED LIGHT BULBS and now I'm really happy with the look! The 6K X5 LEDS cost a few bucks more a pair but the intensity is much more white and clean and they match the OEM illuminated kickplates perfectly.
I highly recommend these too all G37 owners who want a quick, high-quality LED upgrade. Link found below:
2 HID 6K WHITE SMT X5 HIGH POWER LED LIGHT BULBS 194 168 158 2821
Old 10-24-2010, 05:21 AM
  #113
WARAT
WARAT's Avatar
I've been contemplating which one to get but one thing I need to know is, does this bulb fit the door, map, vanity, and license plate light?
Old 10-24-2010, 12:51 PM
  #114
TONY37X
TONY37X's Avatar
These LED's will fit the doors, above rear doors (If you have a sedan), map/dome lamps, license plate, trunk, as well as front running/marker lights. The flip-down vanity lights are different. See my bulb size/spec list I had on another thread below:
Interior: Map Lights 2 x 194 Style LEDS / Puddle Lamps 2 x 194 Style LEDS (One in each door) / Rear Reading Lamps 2 x 194 Style LEDS (One in each) / Trunk 1 x 194 Style LEDS / Glove Box 1 x 57 Style LED / Front Vanity Mirrors 2 x 29MM Vanity Style LEDS
Exterior: Reverse Lamps 2 x 921 Style LEDS / License Plate 2 x 194 Style LEDS / Front Marker Lamps (Upper Outer Corner of Head Light) 2 x 194 Style LEDS (One each side) / Headlamps 2 x D2S Style HID's / Fog Lamps 2 x H8 Style Halogen Bulbs or LED or HID Conversion Kit / Front Turn Signals 2 x 7444NA Mirror Style Bulbs or LEDs with resistor fix.
* All Available on www.v-leds.com *Except the 7444NA's
Old 10-29-2010, 01:24 PM
  #115
amg35
amg35's Avatar
Tony, thanks for this valuable information.
If you don't mind, can you tell me which 921 bulb you used for your reverse lights please?
Thanks,
Allan
Old 10-29-2010, 01:46 PM
  #116
amg35
amg35's Avatar
It seems that a few have used a 921 bulb in place of the 194 for the trunk, is this accurate? If so, which bulb from v-leds is recommended so that the cover still closes?
Thanks.
  #117
2008G-Man
2008G-Man's Avatar
I used these for back-up, they are plenty bright. You won't get a 921 bulb that the dome closes.
V-LEDS HID WHITE 19 M-SMT 8W HIGH POWER BULBS 917 918 920 921 922 923 B/O
Old 10-29-2010, 01:48 PM
  #118
amg35
amg35's Avatar
Thank you very much, I appreciate the wealth of valuable info.
Old 10-29-2010, 03:47 PM
  #119
TONY37X
TONY37X's Avatar
I used the same ones as 2008G-MAN - And Yes, they are plenty bright... also on sale now on V-LEDS
Old 10-29-2010, 03:53 PM
  #120
amg35
amg35's Avatar
Thanks.
My son wanted me to insert the Stormtrooper, he is a big Star Wars fan.
Quick Reply: Just did LED Upgrade-What I Used (FYI)
