Notices
Auto-X Rear Valence
Old 10-27-2009, 09:12 AM
  #61
hispeed-lowdrag
hispeed-lowdrag's Avatar
Originally Posted by Bkdetailing
Dude, What? I never called you. Ever.
A) This is a good place to start. If you had any problems or questions or anything like that...CALL THE VENDOR. Alex and everyone else is very willing and able to help (when you ask for it). There shouldn't be any kind of posting about problems at the very least until you've called/PM'd/texted/etc the person that made/sold it.
2) Saying it is $440 is somewhat misleading in that it sounded like you paid $440 to Autokits. If you paid $150 to paint it somewhere else that's fine but you DID make it sound like Autokits charged you $440 (which it obviously didn't).
D)
Old 10-27-2009, 09:18 AM
  #62
WhosUrBuddiee
WhosUrBuddiee's Avatar
I got mine painted for 50 dollars. Nice having a friend who owns a shop.
But I had the same issues as you. It was simply an installiation issue. I will try to take some pics later. All I did was go to autozone and buy a roll of wider 3M double stick tape and go to my painter.
Here is the roll I bought. My painter already had the promoter spray.
http://www.autozone.com/autozone/cat...uestid=1060745
My Painters Steps
1. Clean the area well
2. Use alcohol whips to ensure all wax and contaminats are removed.
3. Warm the area with a heat gun
4. Apply a layer of adhesion promoter
5. Allow to set for 2 minutes
6. Center rear valance overlay and apply
7. Two people apply pressure (one on each side) for approx 2-3 minutes until firmly set
Mine fits perfect now.
Old 10-27-2009, 12:44 PM
  #63
Bkdetailing
Bkdetailing's Avatar
Originally Posted by xo4ox
Post pics Bkdetailing so we can see what you are talking about, mine fits perfectly, just need to adjust the exhaust tips a bit.
I will get my hands on digital camera and show you guys what it is that i am talking about later today.. I am also going to purchase the promoter, re-line the valence again with the 3m double side tape.
Old 10-27-2009, 12:47 PM
  #64
Bkdetailing
AutoZone.com | BodyMoldingTape | 1/2in.x15ft.MoldingTape
My Painters Steps
I will follow your steps and do the install again myself using the promoter. Thanks man..
Old 10-27-2009, 12:54 PM
  #65
Bkdetailing
D)
1) I posted a thread under the assumption that others may have had the same issues and can provide me with a solution. Without contacting a Vendor. He is saying that I called him. He is thinking of someone else.
2) I didn't make it sound like anything. Its called reading. Instead of glancing over a post, read it in its entirety. Its total cost is 440 dollars I did make that clear. I did make another post elsewhere in a different thread recommending that auto-kits does the paint work.
3) Pictures will be up today.
Old 10-28-2009, 04:29 AM
  #66
ucla bruin
ucla bruin's Avatar
BK, sorry for your frustration. Correct me if I'm wrong but you purchased ALL fiberglass valence right? Do others have the same one or the partially CF one or the ALL CF valence?
I have sitting my garage a polyurethane mold of something thicker than the diffuser that can flex up to 90 degrees on 2 different axis. If you were to make that fit onto the car, it'd be a breeze. I have another piece made out of fiberglass (same shape, except thinner), that has no flex whatsoever, which means not-so-perfect fitment. Then a third piece of CF+resin/epoxy that has a decent amount of flexibility, enough to where it will fit on our car with care.
I am tossing the fiberglass out because in order for me to conform that 100% to my, say rear valence, I would need to make the mold of the valence area while the bumper is installed on the car since the fitment is a little bit different when the bumper is on the car. And even then, I wouldn't be surprised if some pieces don't fit quite right.
Fiberglass is tough to have true 100% fitment. You can be harsh and call it naive for buyers that expect 100% fitment, but you can also say it is tough to advertise a true 100% fitment when it comes to body parts.
What's my point? I'm not telling. But I will say that I will potentially have many CF parts for everybody (and something else).
Also, am I the only one or is no one else picking up the way Autokit responded to the OP? I understand the frustration from both sides (I've been through it too, believe me). But just thought it's interesting that it sounded as if the OP has done Autokit horribly wrong and autokit is the one making the complaints.
__________________
Old 10-28-2009, 05:44 AM
  #67
Ivoidwarranties
Ivoidwarranties's Avatar
Nope, you're not the only one. I'll try and pm you later if I have time Danny.
jfisher
04-25-2017 01:22 PM
andrewk523
11-11-2015 05:49 PM
helloandchau
10-06-2015 05:26 PM
drewfinity
09-24-2015 11:01 AM
m3clubracer
09-13-2015 09:01 AM
Quick Reply: Auto-X Rear Valence
