it's not gonna be bright enough for reverse lights...all that tail light removing to put non bright LEDs
just try the licence plate if not, then the door if not, then the dome
He can put it on the dome only if he isnt going to use it for more than 15 minutes at a time, license plate would burn it out quickly. Yeah they might not be the brightest lights for the reverse lights, but theyre not too bad.
The name of the bulb you bought is V-LEDS HID WHITE 8 M-SMT 4W HIGH POWER BULBS 194 168 158 921 912
So yes they will fit
its not going to work in the reverse. I mean it will but then he will have a hard time to remove it when it burns out because the reverse require a long bulb or it won't shine out. I made the same mistake
Yeah that happened with me too, the bulb went in there and I couldnt get it out. These are actually longer and are easier to remove than what you are talking about.
