Drivers Side Window Not Reseting
Old 03-16-2009 | 07:01 PM
333 4 ME's Avatar
333 4 ME
Brought my G37 out today from it's winter hibernation and noticed that the driver's side window, which as you know slips down a 1/4 of an inch when you open it, does not go back into place when I shut the door. Everytime I open the door, it goes down again, but not back up. I can do the window up all the way when I get in, but it should happen automatically.
Anyone else encounter this issue, and if so how did you correct it?
Old 03-16-2009 | 07:04 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Window reset bro. Hold both window buttons down for 15 seconds, then up for 15 seconds. Should work after that. Search is your amigo Hopefully that'll fix it for ya
Old 03-16-2009 | 07:08 PM
333 4 ME's Avatar
333 4 ME
You da man...it worked. Thanks bro.
Will use search next time....still a newb here.
Old 03-16-2009 | 07:10 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
No problem man. Glad I could help ya out
Oh and welcome to the forum
Old 03-16-2009 | 07:13 PM
333 4 ME's Avatar
333 4 ME
Thanks...glad to be here. Looks like there is a lot of good info on here.
Old 03-18-2009 | 10:04 AM
Ahujadaddy's Avatar
Ahujadaddy
building on that info... i have a problem where the driver side window will roll up when i use the AUTO, but doesnt stay up. It immediately comes right back down about 50%. I tired the resets, took it to dealer, he tried to re-time the window as well using various methods... NO LUCK.
Solution: Dealer ordering me a new window motor
Reason: Driver side window will not re-time
Just thought i'd pass that along in case anyone was havin similar issues.
Old 03-18-2009 | 10:40 AM
When resetting, make sure you don't press the button up/down all the way to the Auto Up or Auto Down position, just the regular up or down position.
Old 10-22-2009 | 01:53 AM
DetroitG37Joe's Avatar
DetroitG37Joe
Ahuja, I have this same problem where when I use Auto-Up, the window goes all the way up and then automatically comes back down 50% of the way. Yet when I use Manual-Up it will go all the way there and stay there. I tinker with the ever mentioned 15-second down and up "window reset" and sometimes it fixes it for a few moments but sure and SOON enough the window will keep doing this again and again. I'm pretty sure I have the same issue and need a new window motor.
Leave it to Infiniti to not even be able to engineer/perfect window technology.
Old 01-03-2010 | 07:35 PM
kkokko's Avatar
kkokko
Will they charge you for a new window motor or is that covered under warranty?
Old 01-03-2010 | 07:37 PM
kkokko's Avatar
kkokko
is the replacement motor covered under warranty? is it 1 yr or more?
Raleclair
10-08-2015 02:06 PM
cvg37s
09-12-2015 07:17 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
Falker11
09-09-2015 08:53 PM
Quick Reply: Drivers Side Window Not Reseting
