Uncomfortable seat belt, digs into your neck? Here's the SOLUTION!
I read the following post that was buried in a long list of pet peevs about the G37. I wanted to post it in a new thread so more people would see it. I was getting really tired of adjusting the seat belt arm down each time I got in the car or when I moved around and the belt arm clicked back into the up position.
This solution worked GREAT for me.![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
Quote from vimish:
This problem is easily resolved with gentle bending. When in the down position, the seat belt extension arm is curved to match the B-pillar so as to permit access to the rear seat; unfortunately, when level, that curvature positions the seat belt into the driver's neck.
Solution:
1. Open the door.
2. Position the seat belt extension arm horizontally level (should click into place).
3. Firmly grab the middle of the seat belt extension arm and gently bend the arm towards the outside of the car. I believe there is a metal liner inside the arm and that seems to keep the adjustment in place.
Bravo! This seat belt positioning is the best I have experienced.
The trade-off: When letting rear passengers in, you’ll have to push the arm slightly inward for it to clear the B-pillar.
Quote from vimish:
Solution:
1. Open the door.
I pulled it by hand all the way out of the car tightly against the pillar, as far as I could. After you bend it, it only retains a small portion of the bend in the spring steel inside the arm, but it's enough to work. Also, if you don't like the position, you can bend it back the same way by hand to return to the original position.
delfinparis
10-08-2015 06:06 PM
butwhatuptho
10-04-2015 07:51 PM
RexHavoc
10-02-2015 11:47 AM
r0cketm0nkey
09-27-2015 01:34 PM
