Help Is there a way to disable the daytime running lights?
I tried to check if this question has been asked before to no avail.
I have those ugly *** conventional daytime runners and there is absolutely no way to turn them off, at least in an apparent method. I've heard that the Canadian G's have this feature.. it's just annoying to not be able to turn it off.
I guess the partial solution would be to change the bulbs to an HID style, so it doesn't look as tacky.
Anyone else out there find any way to disable, or pics of the bulbs changed out?
Thanks.
Thanks.
There are tons of pics of the city/parking lights changed out to white LEDs. Just search around. I don't think there is a way to "disable" it other than to physically remove the bulb, in which case you might as well just swap it with white bulbs.
__________________
__________________
DRL's are required by law in Canada, it's illegal to disable them. All you need to do if you hate the color is swap them out to a whiter colored bulb. LED's will probably burn out quickly from the heat in the headlight housing. I have PIAA Xtreme White bulbs which are close in color to 6000K HIDs.
second, perhaps i'm a tard, but i do have a switch that looks like a foglight switch, and i've change it's position but it doesn't seem to do anything. i have 2 friends who have the G37S and they don't have the daytime runners.
my car is in the shop right now getting repaired from my accident, so i can't mess with it at the moment.
anywho, i guess swappin out the bulbs will make it look less tacky.
thanks.
Definitely sounds like you must have a canadian model. American G's don't have the running lamps. On you headlight control stalk there is a little ring of sorts that controls the fog lamps. When you get your car back look on the regualr turn signal/head light stalk and there you should find the little ring that selects the fog light settings.
I guess I didn't read the OP closely enough. When I think about it, I seriously doubt that he has a Canadian model in the US. It's more likely as the OP stated that he doesn't know how to properly operate the light swithch to turn off the fog lights or parking lights.
If it were a Canadian model, wouldn't all the units of measurement be in metric units instead of imperial? Also, wouldn't the speedo be marked primarily in kph vs mph? I haven't seen a Canada model so I don't know for sure, but it seems likely. Where's our resident Canadian post ****** on this?
My point is, I don't like not having the option of turning my lights off when I want to.
Also, I can't post pics of it because my car is in the shop for the next couple weeks.
For the record, the Singing Fish on the front of a car would be awesome, just not on our cars.
I bought my car from WA, so its possible you may have picked up something that was intended/modified for a cdn customer that backed out?
Anyway, take a peek under the hood and at your battery, and see if you can spot a relay thats is clearly visible. If there is, follow the wiring and there should be an inline fuse somewhere -- find that and pull the fuse out.
