Auto Window Problem
Auto Window Problem
Hey everyone,
I just bought a new '08 G37 6MT yesterday, and very pleased with it.
Though im having a small problem, The Auto adjusting window on the passenger side of the car is not working properly. When i get out of the passenger door, it lowers the window slightly to clear the seal, but when you close the door, it dose not raise back up. Ive tried the procedure in the manual to correct this issue but it still dose it. Mabey im not doing it right. If anyone has any insight on this, id greatly appreacheate it.
Thanks
Thanks
Hey everyone,
Thanks
Thanks
Fist let me say go make an intro in the Noobs section and second take it to you local dealer and have them fix it if the setting procedure does not work then It will probly need a new window motor.
![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
anytime the window controls are unplugged it looses memory, dunno why its setup that way but im sure infiniti has their reasons.
any how the procedure to reset it, is put the window half way. press up and hold it, then press down and hold it for a few seconds. something like 5... when you raise the window it should all work.
symptoms are usually the window wont go up or down when the doors open, but works fine with it closed. and same thing with it only coming down and not going back up for the auto window feature.
i might have the procedure wrong, but keep playing with it and you will get it, the combination is pretty simple once you figure it out.
need a new window motor? how do you figure that?
Well sir they way I figure it is......If he has tried "setting" the window and it still does not fix the issue the he needs to have the window motor replaced !!! read his post and it states it
Try holding the button longer:
https://www.myg37.com/forums/showthr...t=window+reset
Let us know if this works, so others can benefit if you have something really wrong or not.
SuicidalG37SGuy
09-10-2015 06:01 AM
adjustment, auto, autowindow, coupe, g37, g37s, halfway, infiniti, issue, new motor?, opening, passenger, problem, seal, window
