Leaky window sills
Old 10-10-2008 | 03:41 PM
Roseyhebert's Avatar
Roseyhebert
Leaky window sills
I noticed that not long after I got my car and it was rainy the passenger side window leaked by that little front speaker. It doesn't do this all the time either. My G35 did this too on both sides and my mother in law's Z did this too. I know that I need to get the sill replaced but is this a common problem and did anyone else have this too?
Old 10-10-2008 | 03:51 PM
PSYH's Avatar
PSYH
Post Whore
It leaks a tiny little bit if I go into a touchless carwash... it's fine if it's just raining.
Old 10-10-2008 | 03:52 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I haven't experienced this yet on my G37. It did on my G35 twice. I started applying Lexol to keep it compliant and stopped having the issue. I think that the weather and cleaning agents caused it to wear out more quickly.
Old 10-10-2008 | 04:10 PM
Roseyhebert
Did the Lexol leave a film on that part of the window?
Old 10-10-2008 | 04:17 PM
DiamondGCoupe's Avatar
DiamondGCoupe
It's not the rubber the window just wasn't up the entire way. You will notice when you're on the highway sometimes its loud and when you pull the window switches up the windows can go just a bit higher.
Old 10-10-2008 | 04:25 PM
G37GuyOR's Avatar
G37GuyOR
My MoonRoof leaks when i go to the touchless carwash, i haven't had it looked at by the dealer yet... no problems with the windows.
Old 10-10-2008 | 04:35 PM
KAHBOOM's Avatar
KAHBOOM
not after the excess dried
Old 10-10-2008 | 04:37 PM
KAHBOOM's Avatar
KAHBOOM
Actually it is the rubber. The seal shrinks and expands with weather. It also becomes less compliant with weather wear and tear. That's why you notice only certain areas of it leak.
Old 10-11-2008 | 01:26 AM
patmsb1's Avatar
patmsb1
Never had this problem with my 04 Accord Coupe. Hmm?
Old 10-11-2008 | 01:54 AM
NeverBoneStock's Avatar
NeverBoneStock
I have the same problem ...
Old 10-11-2008 | 07:32 PM
chasemyaccord's Avatar
chasemyaccord
I think after a car wash I notice a little bit of water near the left tweeter as well. Not a huge concern since it doesn't happen every time, but I hope this doesn't become a larger issue..
Old 10-11-2008 | 10:55 PM
Loi's Avatar
Loi
mines doesnt leak but when im on the highway doing 70+ wind comes thru and it makes loud annoying wind noise. dealership say theres nothing they cant d o about it.
Old 11-19-2008 | 05:59 PM
BHCubed's Avatar
BHCubed
i had the same problem with my 08 g37. the windows would leak behind the power mirror(triangular piece) down under the tweeter and down the door panel. it only did it when it rained really hard or when i washed my car. i took it to the dealership, they replaced the weather stripping on both windows. so far so good.
Old 11-19-2008 | 06:02 PM
Roseyhebert
Had part of the seal replaced, didn't work, had another seal replace today so we will see if it works. What's funny is that the dealer service department wanted to argue with me because they couldn't get it to leak. I told them to try again and sure enough they called back and said it leaks pretty bad. WELL DUH!!!
Old 11-19-2008 | 06:05 PM
CHI-TOWN G37's Avatar
CHI-TOWN G37
^No Brainiacs there
