LEDs installed for vanity mirrors, doors and license plate
#121
there is a white plastic strap that covers the light bulb on the vanity mirrow. Removing it was not a problem, but when I started to put it back on, it cracked the mirrow. Basically , there are 4 clips that hold the white plastic strap in place: one on the far left side, one on the far right side, and two in the middle. Well, these two in the middle push against the mid part of the mirror when you are trying to insert it back in and that's what cracked the mirror. The solution is to sand these clips down a little. The other mirror did not crack, but it definitely could have since it was tough to stick the white plastic strap back in.
#123
Post Whore
Go to a junkyard and take a mirror from another car then have it cut to size. Someone has done this before and it's a much cheaper solution.
#126
dealer has to order the whole visor and it is like 150 bones. I will find the thread that i tell how to fix it hold on.
#128
Thanks guys for all your help. I tried pulling the visor apart, got ti open somewhat, and then using high power led flashlight, I was able to see two screws that hold both sides together. So to my best knowledge, you can not do it without breaking some of the internal plastic. But, anyway, long story short, got a visor on ebay for $85 shipped. SHWEEEEET. Btw, the dude at the parts department of my dealer wanted $544 for sun visor assembly and he told me it was special order. Does that sound like a bit much?! NO F*CKING WAY I WAS GOING TO PAY THAT MUCH.
#130
you can get it apart. you need a long screw driver and slid it down so you can unclip the pull out. then remove the 2 screws then pull it apart. worth a try befor paying $85 worse case is you wreck it.
#132
damm!!! i was backin up the other night and lookin at the back up camera monitor. i see my LEDs flickering from the license plate. it looked like a friggin raver was busting some light shows behind my ride! time to get new LEDs....i am lookin to get different ones because i want them to be a little brighter.
i got these bad boys last time:
i was planning on gettin these ones now. i dont know if they would fit tho:
anyone got any input?
#133
Hey guys i just replaced my map light LEDs with WLED-CW5 194... they work fine.. but i noticed after I shut my car doors they remain on very faintly... they just have alittle dim glow to them.... is this normal? ... i noticed once i switch from the "door" button to the "off" button they turn off completely
Will this drain my battery or burn out my LEDs? or is this just normal
#135
