LEDs installed for vanity mirrors, doors and license plate
#106
check this out...found this on SoCalG.com. i think im gonna do this too! 12 white LED dome lights http://stores.ebay.com/MotoringMax
(this is from skyline-lexy) so thank him! hope he doesnt mind me posting these up.
#107
Need help!!
Hi all, I bought the LED to replace the license plate bulb from superbrightleds.com. After taking out my license plate light frame, I replaced the bulb. However, when trying to screw it back in, I find that I can't place the clip that holds the screw inside the small hole. No matter how I try, it doesn't seem like it will fit. This is only for the left side of the license plate light "frame". On the right side, the clip goes in just fine with a little pressure from my fingers. Did anyone else have trouble with this? I'm thinking I might take it to the dealership to get them to help me place it back on if nobody has any ideas. Thanks.
#110
Help!!
Now after installing the door lights and dome lights, my door window stopped going back up unless the car is on. Like, when you open the door, you know how the window goes down slightly? It still does that but when you close the door, it doesn't go back up. What should I do?!
#111
Never mind, I fixed the issue with the audo adjusting windows. Apparently it gets reset when you disconnect the battery and you just have to set the setting again and it explained how to do it in the manual.
#112
Are there any explicit directions on how to take the cover off the trunk light to replace the bulb with an LED one? I've been pulling it pretty hard and it hasn't come off. Is there some special way of doing it or has anyone made a video for that? Any help would be greatly appreciated. Thanks.
#113
your better off taking the assembly out . I learned the hard waay and snaped the clip off it is hard to get open with out breaking it especially when it is cold
#114
#118
For right w/o sunroof it says:
1 = 1
partid = 7921127
Catalogid = 2
part.price = 252.05
part.listprice = 406.53
part.partnumber = 96400JL30A
part.partcost = 252.05
part.corePrice = 0.00
For left w/sunroof it says:
1 = 1
partid = 7921169
Catalogid = 2
part.price = 252.05
Which makes me think it is same part w/ or w/o sunroof so only choice is left or right.
Sure is an expensive part. Good luck.
