Lighting up when you unlock the door?
Okay, good to come across this thread because I thought I was seeing things.. this recently has been happening to me and my lights were on AUTO. Happened twice in the past 3 days when it's dark.
I wonder is it a glitch.. I don't think Infiniti intended for the car to do that honestly.
But for sure, it happened to me on auto. The only problem is that it's not consistent nor can I duplicate it by choice but it rather happens randomly.
Not 100% sure, but I believe if you switch your lights to "ON" and not automatic, and you get out of the car, your lights will remain on longer than the 45 sec when they are on automatic, however, I believe they still turn off after a few minutes to avoid your battery from draining completely. So obviously, once the lights are switched to "ON" then you may get what you're describing...
Again, not sure on this, just an educated guess.
After a night out this happened and I think I finally learned the trick.
1.When you park, make sure headlights are on auto
2. Switch headlights to off.
3. Turn car off
4. Open door
5. Switch headlights to auto
6. Get out car.
7. Lock doors.
8. Whether you come back in 1 minute, or 3 hours like I did, the headlights should come on like the luxury cars when you unlock the car via keyless entry or the FOB.
However, the moment you close the door it turns off when you get in. So start the car or switch the ignition to on after you open the doors if you want the lights to stay on. Makes getting in the car at night easier and more appealing. Hope this helps!
*This was on an 08 G37s
3. Turn car off
4. Open door
6. Get out car.
7. Lock doors.
fmrlegend (02-02-2015)
B Feelgood
09-13-2015 05:56 PM
