Orange rear turn signal LEDs for UK G37???
I am likely to be moving to the UK in a few weeks. I'm trying to plan everything. Apparently to have my G37 be legal in the UK the signal lights have to flash orange - that is I have to change out all those red LEDs for orange ones! Anyone know where I can get some orange LEDs? How hard would this be to do?? Should I do it before I go since maybe it'll be harder to get in done there??
I'll have to get little repeater lights fitted on the sides too!
Actually - I just realized that the turn signal doesn't use the LED's - just uses the central bulb! Sorry! A 21watt bulb which I have to assume is pretty easy to get replaced in England!
1st no one will give a flying *** if you have orange turning signals or not
2nd in case you never looked at your taillights (which you apparently didnt), the lens on the outside of the taillight is RED, not CLEAR, so even changing the bulbs to GREEN will still result in RED flash.
3rd if you're so concerned, get JDM taillights that have an orange cut out for the turning signal.
Might actually be a good plan.
lol, seriously putting an orange bulb will not make it appear orange, because your taillight is red
I'm sure if you would have been the target to that comment, either:
a) You would have gone running straight to delete the post.
b) You would agree with everyone else saying that he "woke up on the wrong side of the bed."
edit: c) All of the above
