Full Carbon Fiber Interior Replacements
#151
I would like to buy the door pulls, which I believe are $250.. I did not see the door pulls & couldn't register..can someone tell me where I go to purchase the door pulls for this price??
#153
I sense some people are slightly mistaken.
The parts are OEM parts vacuumed wrapped in real CF, they are not fiberglass replicas or any templates, so the fit is 100% guaranteed. Which is why we have core exchange program to ensure the availability of usable parts.
Only the door pulls will be made in Solid dry carbon, meaning the entire piece will be in carbon, no factory core under it. (for individual orders only)
#156
What I can suggest is actually buying the handle from the 08, if it doesn't fit directly, the aluminum is actually just bent over the handle, so I imagine you can try to retrofit that.
#159
Here is DIY on the most "difficult" parts.
https://www.myg37.com/forums/faq-and...or-pieces.html
Pretty sure the rest of the pieces are simply "tabbed". I have the door handles on order in a non-black color to see if I want the rest of the set. They are suppose to be in mid-January and I will post pics when I install unless someone else does it sooner. When you have the new part in hand, it should be obvious where and how to remove the OEM ones and install these pieces. At least that is my plan. or to be determined.
